muddauber
Jul 09, 2015Aspirant
Ultra 4 will not power up
After rebuilding my failed system, it will now not POWER UP. It will whirl for a second or two when I push the power button, then quit.
mdgm-ntgr
Jul 09, 2015NETGEAR Employee Retired
Does it get any further if you power down and remove your disks (label order) then try booting. It should give an error "No Disks Detected" when you boot with no disks installed.
Can you access the boot menu?: http://kb.netgear.com/app/answers/detail/a_id/21104
