bart_bcit_be
Sep 04, 2011Aspirant
Ultra 6 + SLOW after replacement of 2TB HD's by 3TB HD's
I have a ReadyNas Ultra 6 and just replaced 4 2TB HD's (Hitachi HDS722020ALA330) with 4 3TB HD's (Hitachi HDS723030ALA640) and my speeds dropped from +/- 100 MB/s to 50 MB/s. I use the x-raid2 and ...
bart_bcit_be
Sep 05, 2011Aspirant
Thank you for the info.
I will do some additional tests this evening (connect laptop with cross-cable directly to NAS, replace Procurve 1800G24, start iscsi and check speeds, ...).
If the result is the same, I will open a case.
But just another question about the x-raid. If I now add 2 TB HD's (next to the 4 3TB HD's) I will still gain 2 TB of diskspace?
Thank you.
Thank you.
