Jophus
Dec 16, 2016Luminary
Ultra 6 6.4.2 disk fail issues
Hey All. Wanted to relay a story to you all around how my Ultra 6 on 6.4.2 suffered a disk failure, rebuilt, locked up, then worked perfectly... Disk in questions was a 2GB Seagate: Dec 14 13:3...
Dec 16, 2016Guru - Experienced User
I'd run a disk test from the admin ui.
Jophus
Dec 20, 2016Luminary
Disk test took 5hrs 55 minutes on XRAID2 (dual redundancy) for 5x1.5TB+1xTB (6TB volume - 5.44TB useable) and found....
NO ISSUES!!! All disks healthy.
- StephenBDec 21, 2016Guru - Experienced User
Great!
- mdgm-ntgrDec 21, 2016NETGEAR Employee Retired
The first thing you definitely should get your backup up to date if you haven't already.
Which model SeaGate 2TB is it?
6.4.2 is over 10 months old now. We have newer firmware available.
- JophusDec 21, 2016Luminary
mdgm wrote:The first thing you definitely should get your backup up to date if you haven't already.
Backup is done weekly on an RN102
ST2000DL003-VT166
Given debacle of 6.4.0, and a finally-stable 6.4.2, I won't be upgrading until 6.6.1 or 6.6.2 is out. There is no need to have the latest version in a production box.
