benoitmabille1
Dec 19, 2015Tutor
Ultra 6 plus - SMB not advertised anymore
Hello, ULTRA6 PLUS 6x3TB Xraid2 OS 4.2.28 36% capacity used Suddenly the SMB shares are no more showing on the windows clients - not related to 4.2.28 upgrade. Shares are still accessible...
- Dec 26, 2015Resolved !
1) in /etc/var/log/samba/log.nmbd
nmbd version 3.6.25 started.
Copyright Andrew Tridgell and the Samba Team 1992-2011
standard input is not a socket, assuming -D option
invalid permissions on socket directory /var/nmbd :manfrustrated:
ERROR: nb_packet_server_create failed: NT_STATUS_UNSUCCESSFUL
2) Change the permissionto 755 (it already was but probably a 'glitch' happened)
3) Restart nmbd
NAS:/etc/samba# nmbd -i
YES ! Thank you Google and a few hours of time...:womanlol:
benoitmabille1
Dec 20, 2015Tutor
Hello,
Yes, the name is not recognized anymore. I thought I got access via IP but in fact not.
Admin & shares are accessible (shares is empty). And Other folders not accessible.
I have SSH & Frontview.
Maybe some service not running ?
Dec 20, 2015Guru - Experienced User
Log in with ssh, and check the fullness of the OS partition
df . -h
df . -i
- benoitmabille1Dec 20, 2015Tutor
With the SSH GUI, I can browse thru directories. I could download a file - data is still there.
NAS:~# df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 30075 35461 46% /
NAS:~# df . -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 1.4G 2.5G 36% /
NAS:~#NAS:~# df -h
tmpfs 16K 0 16K 0% /USB
/dev/c/c 11T 3.9T 7.0T 36% /c
/c/home 11T 3.9T 7.0T 36% /home/ftp/homes
/c/Dropbox 11T 3.9T 7.0T 36% /home/ftp/Dropbox
/c/cams 11T 3.9T 7.0T 36% /home/ftp/cams
/c/medias 11T 3.9T 7.0T 36% /home/ftp/medias
/c/partage 11T 3.9T 7.0T 36% /home/ftp/partage
/c/utilisateurs 11T 3.9T 7.0T 36% /home/ftp/utilisateurs
NAS:~# df -i
tmpfs 255677 1 255676 1% /USB
/dev/c/c 182683648 537274 182146374 1% /c
/c/home 182683648 537274 182146374 1% /home/ftp/homes
/c/Dropbox 182683648 537274 182146374 1% /home/ftp/Dropbox
/c/cams 182683648 537274 182146374 1% /home/ftp/cams
/c/medias 182683648 537274 182146374 1% /home/ftp/medias
/c/partage 182683648 537274 182146374 1% /home/ftp/partage
/c/utilisateurs 182683648 537274 182146374 1% /home/ftp/utilisateurs
NAS:~#- StephenBDec 20, 2015Guru - Experienced User
Your OS partition is not full, so that cause is ruled out.
Can you see the files with FTP?
Did you try restarting the NAS?
- mdgm-ntgrDec 20, 2015NETGEAR Employee Retired
Also, which version of Windows are you running on your client machines?
Is the NAS in the same workgroup as your client machines?
