norb1100
Dec 08, 2020Aspirant
ULTRA 6 RNDU6000 Single redundancy to dual
Hello I want to move from single to dual redundancy in my Ultra 6 but option in frontview is missing. Originally four 2tb drives and one 4tb drive and now 3x4tb, 1x2tb and 1 6tb. After disk replacm...
Dec 08, 2020Guru - Experienced User
Normally you'd need 3 disks of the largest size to go to dual redundancy (at least that's the case if you don't want to waste space). So your 6 TB drive might be getting in the way here.
I don't know of any way to fix this in Frontview, apart from doing a reset.
- norb1100Dec 08, 2020Aspirant
Can I replace that 6tb with 4tb or thats not possible?
thanks
- StephenBDec 08, 2020Guru - Experienced User
Yes you can. Hopefully that will restore the dual-redundancy option.
If you do need to do a factory reset, you could take the opportunity to convert the NAS to run OS-6.
I just relized that I made a mistake, i dont have 6tb disk in my nas, i have four 4tb drives and one 2tb drive. Does it make any difference now?
Still last option is to replace that 2tb drive with 4tb?
Thanks
