norb1100
Dec 08, 2020Aspirant
ULTRA 6 RNDU6000 Single redundancy to dual
Hello I want to move from single to dual redundancy in my Ultra 6 but option in frontview is missing. Originally four 2tb drives and one 4tb drive and now 3x4tb, 1x2tb and 1 6tb. After disk replacm...
norb1100
Can I replace that 6tb with 4tb or thats not possible?
thanks
Dec 08, 2020Guru - Experienced User
Yes you can. Hopefully that will restore the dual-redundancy option.
If you do need to do a factory reset, you could take the opportunity to convert the NAS to run OS-6.
- norb1100Dec 08, 2020Aspirant
I just relized that I made a mistake, i dont have 6tb disk in my nas, i have four 4tb drives and one 2tb drive. Does it make any difference now?
Still last option is to replace that 2tb drive with 4tb?
Thanks
- StephenBDec 09, 2020Guru - Experienced User
Then you should have the option to add a disk for redundancy.
I'm not running OS 4.2.x anymore, so I don't recall exactly where this setting is for XRAID. I think it is on one of the volume pages in Frontview, so maybe check all of those pages. Also it requires 4.1.16 firmware or later - likely you are already running that, since you've seen the option before.
- norb1100Dec 09, 2020Aspirant
Replaced 2tb drive with 4tb and still option for dual redundancy is not there.
Without that option adding 6th drive will only expand volume i believe.
