norbert1
Aug 06, 2014Aspirant
ultra 6 volume size
I want to upgrade my Ultra6 RNDU6000 RAID-5 with larger drives but not sure what is max volume can be. I read that max is 16tb is that correct? thanks
mdgm-ntgr
Aug 06, 2014NETGEAR Employee Retired
What disks do you currently have installed?
What disks and capacity were installed when you last did a factory reset?
If you want a larger volume than 16TB you would have to do a factory reset with the drives in place.
Please take a look at our compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641 (Select Legacy, then Ultra 6).
