norbert1
Aug 06, 2014Aspirant
ultra 6 volume size
I want to upgrade my Ultra6 RNDU6000 RAID-5 with larger drives but not sure what is max volume can be. I read that max is 16tb is that correct? thanks
Aug 08, 2014Guru - Experienced User
xraid2 is fine.
norbert wrote: i checked my box and i have x-raid2, does it make any difference?
Also i noticed that 4tb drives and reasonably priced now, can I use 4tb instead of 3tb without resetting the box?
Thank you
Adding 2x4TB is an option, and will give you 6 TB of more space. If you are still under warranty it could be an issue, since Netgear will deny support if you stray from the HCL.
