nlaredo
Aug 22, 2013Aspirant
Ultra6 rebuild always ends with "complete" and then "Dead"
I have an Ultra6 where drive 1 failed, so I bought a new drive 1, and then it started rebuilding. After popping up a dialog that the rebuild was complete, it told me that my array was dead because of...
Aug 24, 2013Guru - Experienced User
I agree it would be nice. Cloning the bad drives does the same thing, but requires that you already have the replacement drives.
nlaredo wrote: Yes, my biggest complaint here is that netgear failed to give me a user option to ignore the drive errors and complete the rebuild anyway and just tell me which files are now corrupted by the roughly ~4k of bad blocks vs declaring the whole array dead...
BTW, Scrubbing [prior to the main failure] would have uncovered/reallocated the bad blocks too, so perhaps setting up a scrubbing schedule after you get it rebuilt would be a good idea.
If you are talking about bytes written, then it could be due to the different file system. How large a discrepancy are you talking about?
nlaredo wrote: On the RN516, the backup is *larger* than the original ultra6 data used.
Enabling ssh (and adding tools) doesn't void the warranty, though of course if you do something which destroys the OS, etc Netgear won't help.
nlaredo wrote: ...I guess I could root the ultra6 and put the right tools on there (like hdparm) if they aren't already there, but I didn't want to void any remaining warranty.
