sapmec
Oct 30, 2022Aspirant
Unable to access boot menu on ReadyNAS 2304 using Reset + Power button combination
Hoping someone can provide some hints as to next steps. I have google'd and searched through this forum for different variations of 'cannot access boot menu' with and without 'readynas 2304' key word...
sapmec
Nov 06, 2022Aspirant
OK...thanks for the info...unfortunately, the NAS just powers up normally with the USB Recovery drive in either the front USB port or I tried one of the rear USB ports. With the NAS off and the USB Recovery drive plugged in I depress the Reset button until I hear/feel the 'click', then I touch the Power button and keep the Reset button depressed. After about 12 seconds the power light goes solid and nothing else happens. This is the exact same behavior as when I've tried to get into the Boot menu holding the Reset button down (without the USB Recovery drive plugged in) and powering on (with and without drives, plugged in and unplugged from network).
In terms of the NAS shutting off due to temperature sensor...I'm not sure that was a symptom as I can leave the NAS powered up (and undiscoverable) and it does not power off abruptly or anything like that...
Any other ideas? and thanks for the help that's been provided so far...much appreciated!
Sandshark
Nov 06, 2022Sensei
The 2304 has a (mini, I believe) display port, so I suggest you connect to it and a keyboard on USB and see if you get any additional clues watching what's happening during the boot. You may also be able to see something if you go into the BIOS settings, like if a voltage or temperature is showing up as out of spec. I've never had a 2304, but I believe those should work. They do with units that have an HDMI port.
