keenan1
Dec 09, 2011Aspirant
Unable to access the data volume after disk replacement
Summary: After a hard drive failure and hot-swap, all volumes have disappeared. I'm not sure but believe this was caused by some Smart Errors on a second drive while the replacement drive was being ...
mdgm-ntgr
Dec 09, 2011NETGEAR Employee Retired
When a disk is added (e.g. to replace a failed disk) a resync occurs. A resync puts heavy stress on all disks. So if a second disk is failing the resync can finish it off. I would suggest you work with NetGear tech support on this issue. It's good practice to include the case number in the title of the thread (i.e. subject of first post in the thread).
