zhenya
Jun 23, 2016Aspirant
Unable to connect to a Mapped Drive
All of sudden I am unable to connect to any of my shares from any of my windows machines. MappedDrive, \\READYNAS, \\<IP ADDRESS>, \\READYNAS\<SHARE>, none of them are working. I get an error message...
JennC
Jun 24, 2016NETGEAR Employee Retired
Hello zhenya,
What's the FW version and model number of your NAS?
If you have multiple users and the share permissions are set to Everyone, can you try removing Everyone from one of them and try accessing that share then log in using at least one of the users that are allowed to access it. Then try other folders, once done, try other users too.
zhenya
Jun 24, 2016Aspirant
It's ReadyNAS 312 Firmware 6.5.1
- JennCJun 24, 2016NETGEAR Employee Retired
Hello zhenya,
Have you tried the above suggestion?
- JohnRoJun 27, 2016NETGEAR Employee Retired
Hi zhenya,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- mike_coreitSep 12, 2016Aspirant
Hi I recently experienced this same issue when updating to 6.5.1. I was able to resolve it by disabling IPv6 on the NAS drive
- BrianL2Sep 14, 2016NETGEAR Employee Retired
Hi mike_coreit,
Thank you for sharing the solution you had in fixing this issue. It is possible that your computer is trying to connect to your ReadyNAS (shares) via IPv6 protocol. Let's keep this option disabled so you won't have problems accessing your shares via File Explorer.
Kind regards,
BrianL
NETGEAR Community Team
