ChrisJay
Jul 07, 2017Aspirant
Unable to connect to Admin Page on RN2120 after firmware 6.7.5 upgrade
Hello all, I have a NetGear ReadyNAS 2120 which has never missed a beat until last week when I upgraded the firmware to 6.7.5 (latest). The unit rebooted as normal however after I was unable ...
Jul 07, 2017Guru - Experienced User
Are you only losing the web ui? Or are you losing access to the shares also?
- ChrisJayJul 07, 2017Aspirant
The NAS has vanished off my network.
IP no longers responding, RAIDar shows no NetGear NAS, its like the unit isn't even there.
- StephenBJul 07, 2017Guru - Experienced User
Then powering down, removing the drives (labeling by slot) and powering up is a reasonable next step. If the chassis is working, you should get a "no disks" status from RAIDar.
You could also run a memory test from the boot menu (see page 13 here: http://www.downloads.netgear.com/files/GDC/RN2120/ReadyNAS_OS_6_Rackmount_HW_UM_10Dec2014.pdf )
While the disks are out, you could also connect them to a windows PC (usb is ok) and run the vendor diags (seatools for seagate, lifeguard for western digital).
I powered the unit off, ejected all the drives then powered the unit back on and it looks to be working.
RAIDar first showed a message of 'System starting up ..' then it changed to 'No disks detected'. The unit now has a IP from my DHCP pool .15 however I'm unable to assess the Admin Page, I suspect this is normal.
I powered the unit off again, inserted the drives then powered the unit back on and again there is no sight of the NAS on the network.
