ChrisJay
Jul 07, 2017Aspirant
Unable to connect to Admin Page on RN2120 after firmware 6.7.5 upgrade
Hello all, I have a NetGear ReadyNAS 2120 which has never missed a beat until last week when I upgraded the firmware to 6.7.5 (latest). The unit rebooted as normal however after I was unable ...
Jul 13, 2017Guru - Experienced User
You should be able to boot up the unit with three working disks (assuming XRAID or a flexraid mode with redundancy).
Your data is of course not protected until you replace the failed one.
Was the drive provided by Netgear? Or are the RMA comments about the NAS itself?
TiggerTonk
Jul 28, 2017Aspirant
Also updated to this version of the OS and have the same lack of connection to the admin page. Still can access the shares and (hopefully) all the files on them via a mapping to the fixed IP but no browser, telnet or SSH access can be made.
Display panel correctly shows correct (fixed IP) on start-up 192.168... but before any access can be attempted flicks to a random 169.254.. .one. Tried a direct connection via crossover cable but attempting to use IP address in either range is met with the same response as when connected via router.
Could login before firmware update, wishing I done my monthly off-line backups before accepting the firm patch!
