Sam_N
Dec 28, 2012Aspirant
Unable to connect to Duo v2 from Snow Leopard
I've had my Duo v2 for a bit more than a year and recently have had problems since getting a new computer. I had never had a problem with my old computer and the Duo working together including through...
ReadySECURE
Jan 17, 2013Apprentice
What protocol are you using? CIFS or AFP?
Try CIFS instead of AFP is you're not using CIFS.
Connecting to CIFS is just like AFP, except you change AFP to SMB in the Connect to Server dialog.
Finder > Go > Connect to Server > smb://ipaddressofnas
I'm trying to eliminate AFP as your problem.
Also, download logs and post your afp.log
