ramasaig
Aug 06, 2012Aspirant
Unable to connect to 'source'
I've been running a ReadyNAS Duo V2 for about three years with a WinXP machine. No problems whatsoever. I have recently retired that m/c and replaced it with a Win7 x64 machine. I've used much the ...
Aug 06, 2012Guru - Experienced User
BTW, it looks like the NAS is able to access one hard drive, and not the other?
Are both drives formatted identically (I am wondering if one is NTFS and the other is FAT32 for instance).
Also note that in Windows the share permissions and the file/folder permissions are distinct. Windows intersects the permissions, so the result can be more restrictive than either (and is never more permissive).
