ramasaig
Aug 06, 2012Aspirant
Unable to connect to 'source'
I've been running a ReadyNAS Duo V2 for about three years with a WinXP machine. No problems whatsoever. I have recently retired that m/c and replaced it with a Win7 x64 machine. I've used much the ...
Aug 06, 2012Guru - Experienced User
4.1.x firmware is definitely V1 (sparc platforms). The problem is that Netgear also uses v1, v2, v3... as minor hardware upgrades. In this case, they used "v2" to mean two different things in the same product family.
Anyway, you keep talking about the sharing settings (which are relevant of course). But you haven't talked at all about the security tab settings, and they are just as important. The most restrictive setting in both categories is what determines the effective permissions. Maybe as a test you can add "everyone" as a user on the security tab and give them full control?
