ramasaig
Aug 06, 2012Aspirant
Unable to connect to 'source'
I've been running a ReadyNAS Duo V2 for about three years with a WinXP machine. No problems whatsoever. I have recently retired that m/c and replaced it with a Win7 x64 machine. I've used much the ...
Aug 06, 2012Guru - Experienced User
Full control read permissions will allow anyone connected to your home network to read the files.
The other computers are likely using credentials (username/password) that the new PC recognizes.
You can try putting the PC username/password on the source in the backup job - that might allow you to tighten up the permissions.
You could also create a new user on the PC that has read access to the files, and use that user/password on the source.
