dischler
Aug 30, 2015Tutor
Unable to create RAID 0 volume on ReadyNAS duo v2 with two disks
I have a ReadyNAS duo v2 with two identical 3TB disks that used to be running X-RAID2. I want to change it to RAID 0, so that I will have a single 6TB volume (without redundancy). I've tried ...
- Sep 01, 2015
Give RAIDar 4.3.8 a try then.
Aug 30, 2015Guru - Experienced User
Are you following the procedure on page 22-23: http://www.readynas.com/download/documentation/UM/RAIDiator5-3_Home_SW_en_Nov711.pdf
Though I don't recommend creating a RAID-0 volume that spans multiple disks. It is very fragile (either drive fails and the entire volume is lost).
