dischler
Aug 30, 2015Tutor
Unable to create RAID 0 volume on ReadyNAS duo v2 with two disks
I have a ReadyNAS duo v2 with two identical 3TB disks that used to be running X-RAID2. I want to change it to RAID 0, so that I will have a single 6TB volume (without redundancy). I've tried ...
- Sep 01, 2015
Give RAIDar 4.3.8 a try then.
Dr_Data
Aug 31, 2015Aspirant
I'm having the same problem, did you find a resolution?
mdgm-ntgr
Aug 31, 2015NETGEAR Employee Retired
Which version of RAIDar are you running?
You may need to use the older version: RAIDar 4.3.8
- dischlerAug 31, 2015Tutor
StephenB: Yes, I'm following the procedure in the manual, basically pages 24-25.
In step 3 on page 25 I select "0" from the drop down menu where it says "Select the desired RAID level". However, when the setup finishes the system is RAID 1. It thus seems that the installer ignores this selection, and automatically assigns a RAID level as described in the table at the top of page 28.
(Note: I'm well aware of the danger of running RAID 0, but I have enough redundancy elsewhere; another NAS, cloud, external disks etc...)
mdgm: I'm using RAIDar 5.3 I'll try your suggestion and use RAIDar 4.3.8. Will update the case when done.
- mdgm-ntgrAug 31, 2015NETGEAR Employee Retired
There is no RAIDar 5.3.
I am referring to the RAIDar client on your PC not the RAIDiator firmware on the NAS.
mdgm: Ah, sorry. I was not at home when I wrote the reply, so I didn't actually check. I'm still not home, but I'm pretty sure it is RAIDar 6.0 because I downloaded RAIDar quite recently before starting this attempt to change RAID level. And the GUI looks exactly like this: http://kb.netgear.com/app/answers/detail/a_id/27391/~/introducing%3A-raidar-6.0
