Paul_Thomas
Mar 21, 2018Aspirant
unable to register product - already registered
Hi, I've just purchased a second ready nas, used from ebay. The seller says the unit is 10 months old, so I'd like to register it and have the remainder of the warranty (5 years?) However, I ca...
- Mar 21, 2018
Paul_Thomas wrote:
Does this also prevent you using the warranty?
The warranty is not transferrable (which is why the registration can't be changed). You also won't be able to use paid Netgear support.
Paul_Thomas
Hi,
Thanks for your fast response. Does this also prevent you using the warranty? I'm used to transferable warrenties which I have used on several occasions for second user HP products.
Thanks
Paul
Mar 21, 2018Guru - Experienced User
