Retired_Member's avatar
Retired_Member
Nov 12, 2019
Unable to Register Product - Already Registered
Hi,
I have recently installed the Nighthawk app and when I try to enable Remote Management it says my device is already registered with another account. I have also logged into MyNETGEAR and tried to register my device and it says "This serial number is already registered to another customer. Please email NETGEAR support [email protected] for help."
I tried to email customer service a couple of times with no reply. I have read some other threads and support seem to be able to fix the issue if it's posted here. Please help.
Thanks
  • Thanks Christian_R
    Netgear support did contact me.
    In my case, it appears i had registered the router under a different email address - which i picked up when Netgear support responded to me on that email address (Telling me they could not find anything wrong :smileyhappy:
    I now need to manage the router remotely using one email address and use the other for everything else - which is ok.
    Not sure if i can actually mark this thread as closed or solved. But that was a quick turnaround !
    Kevin
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello m1nt,
    Welcome to the Community! Please send me a private message with your email address and serial number and I can forward it to our Customer Care for assistance.
    Christian
    • Retired_Member's avatar
      Retired_Member
      Hi Christian_R,
      I haven't heard from customer care again - they seem to have dopped of the earth. Can you please help? I have PM'ed you my info.
      Thanks heaps!
      • Kevin_Edwin's avatar
        Kevin_Edwin
        Tutor
        Hi all
        I purchased this device in Aug 2016 and have the latest firmware.
        I am trying to enable remote management - for a simple reason - the USB connected to it for some reason ocassionally does not get recognised. I need to reset/reboot and it comes back again. So i am hoping by remote management, when i am travelling, i can reboot the router to fix the issue - if it occurs.
        I have the same issue of it being registered previously. I have always used the same Netgear account so cannot say i have used another account.
        Would someone be able to help. Thanks
        Kevin
    Retired_Member
    Thanks guys! Customer Service have finally replied - must have seen this haha. I'll post back if there are any issues.
