EricFalsken
Oct 19, 2015Follower
Understanding Drive-swapping
So I've recently upgraded all of the drives in my ReadyNAS Business. I did it by shutting down my ReadyNAS and pulling ALL of the drives out. Then pushing 6 new drives into it and turning it back on....
- Oct 19, 2015
If you upgraded firmware after you swapped out, then the NAS will upgrade the firmware when you boot up on the old disks. That is, it will check the firmware on the OS partition, and if it differs from what is in the flash it will upgrade (or downgrade).
But all the settings, etc are stored on the drives. So you can swap back (being careful to power down, swap disks, power up).
Oct 19, 2015Guru - Experienced User
