Beno15
Oct 09, 2014Aspirant
Understanding RAID-X basics for data recovery
Hi, I'm looking for some help about the fundamentals of the storage technology used by the ReadyNAS Duo, in order to perform a data recovery, or a way to restore the ReadyNAS Duo without erasing ex...
mdgm-ntgr
Oct 09, 2014NETGEAR Employee Retired
a) How do you mean data was lost? Can you describe what happened that led you to this conclusion
c) and d) With X-RAID on the Duo v1, it is normal for only one disk to have a partition table on it. In this case disk 2 is the dedicated parity disk which does not have a partition table on it. Newer models use distributed parity across all the disks and don't have a dedicated parity drive.
e) Told by whom?
1) You could do it on just disk 1 (the one with the partition table).
2) Only on one of the two disks in the Duo. See comment above
3) Assuming the data is still there, this may help: http://home.bott.ca/webserver/?p=306 - I assume you still have the clones? These could be useful if something goes wrong with attempting data recovery.
5) If I have a remote look at your system in a low-level diagnostics mode I may be able to give an answer on that.
e) Told by whom?
