Beno15
Oct 09, 2014Aspirant
Understanding RAID-X basics for data recovery
Hi, I'm looking for some help about the fundamentals of the storage technology used by the ReadyNAS Duo, in order to perform a data recovery, or a way to restore the ReadyNAS Duo without erasing ex...
Beno15
Oct 10, 2014Aspirant
When above link is down, you can still find the page with the WayBackMachine:
3) Assuming the data is still there, this may help: http://home.bott.ca/webserver/?p=306
https://web.archive.org/web/20140711191324/http://home.bott.ca/webserver/?p=306
I followed the four first steps of the procedure mentioned by the link.
Using CentOS, they were no available rpm packages. Furthermore, compiling from source lead me from problem to problem due to lacking dependencies. So I used Ubuntu (like in the procedure) and it was easy to install the binary packages at steps (2) and (3).
At the step (5) of the procedure "vgscan" give no result at all. Just a message telling that the scan could last a while.
The drives were within the NAS, which was connected through an Ethernet wire.
Should I have use an USB wire instead?
Also, at the step (7) of the procedure, I don't understand what "/dev/c/c" mean. I'm familiar with "/dev/sda1", a.s.o, but not with the "/c/c". What does it denote?
Thanks a lot.
