Beno15
Oct 09, 2014Aspirant
Understanding RAID-X basics for data recovery
Hi, I'm looking for some help about the fundamentals of the storage technology used by the ReadyNAS Duo, in order to perform a data recovery, or a way to restore the ReadyNAS Duo without erasing ex...
mdgm-ntgr
Oct 11, 2014NETGEAR Employee Retired
Not sure about your ideas, but you could give them a try and hopefully you will be able to let us know what works for you.
Could be hard to get the data back (if even possible) let alone keeping the folder structure.
Not knowing what "reset" your friend did does make it difficult to assess the situation.
Please encourage your friend to backup important data primarily stored on the NAS in future. No important data should be stored on just the one device.
