sjf1's avatar
sjf1
Unicode Issue?
I'm trying to copy my iTunes library from an older ReadyNAS NV+ to a brand-spankn-new 2120. This issue is that the 2120 seems to choke on unicode characters (or at least characters with umlauts, etc.)
Using an iMac, I've created two mounts, one to the NV+ and the other to the 2120. I then tried cp, rsync and ditto to copy the library over. I'm getting errors such as…
    cp: /Volumes/media/Music/iTunes/iTunes Media/Music/Charlotte Church/Voice Of An Angel/11 Suo-Gân.mp3: No such file or directory
    cp: /Volumes/media/Music/iTunes/iTunes Media/Music/Il Divo/Ancora/04 You Raise Me Up (Por Ti Seré).mp3: No such file or directory
    cp: /Volumes/media/Music/iTunes/iTunes Media/Music/Il Divo/Ancora/05 Si Tú Me Amas.mp3: No such file or directory
    cp: /Volumes/media/Music/iTunes/iTunes Media/Music/Luciano Pavarotti, Giuseppe Patanè; National Philharmonic Orchestra: unable to copy extended attributes to /Volumes/Music/iTunes/iTunes Media/Music/Luciano Pavarotti, Giuseppe Patanè; National Philharmonic Orchestra: No such file or directory
In rsync, it complains that the files have 'vanished'.
In searching this site I see references to allowing unicode in user, group and share names, but these are in file paths and names. Anyway, I couldn't find that option on firmware 6.1.4.
I did find a comment in the software manual… "ReadyNAS OS 6 supports unicode."
Any help would be appreciated.
  • StephenB's avatar
    What happens if you copy the files to a folder on the iMac?
  • Well, I have some more information…
    It seems the sensitivity is a function of the type of mount being used to connect to the source NAS (an NV+).
    iTunes uses the (NFS) mount…
    nas2.controlsoftcorp.com:/media on /Network/media (nfs, nodev, nosuid, automounted, nobrowse)
    Finder creates the (AFP) mount…
    //sjf@nas2%20%28AFP%29._afpovertcp._tcp.local/media on /Volumes/media (afpfs, nodev, nosuid, mounted by sjf)
    Only the AFP mount seems to have issues with umlauts. Rsync seems to have issues seeing the file. For example I did a directory listing of the same directory through the 2 mounts, and got the following results.
    sol:Music sjf$ rsync -a /Volumes/media/Music/iTunes/iTunes\ Media/Music/ /Volumes/Music/iTunes_from_Volumes/
    file has vanished: "/Volumes/media/Music/iTunes/iTunes Media/Music/Il Divo/Ancora/04 You Raise Me Up (Por Ti Sere?\#201).mp3"
    file has vanished: "/Volumes/media/Music/iTunes/iTunes Media/Music/Il Divo/Ancora/05 Si Tu?\#201 Me Amas.mp3"
    rsync warning: some files vanished before they could be transferred (code 24) at /SourceCache/rsync/rsync-42/rsync/main.c(992) [sender=2.6.9]
    sol:Music sjf$ ls -al /Volumes/media/Music/iTunes/iTunes\ Media/Music/Il\ Divo/Ancora/
    ls: 04 You Raise Me Up (Por Ti Seré).mp3: No such file or directory
    ls: 05 Si Tú Me Amas.mp3: No such file or directory
    total 104096
    drwxr-xr-x 1 sjf staff 330 Dec 28 14:54 .
    drwxr-xr-x 1 sjf staff 264 Dec 26 12:23 ..
    -rwxr-xr-x 1 sjf staff 7504453 Sep 21 2008 01 All By Myself (Solo Otra Vez).mp3
    -rwxr-xr-x 1 sjf staff 8199903 Sep 21 2008 02 Isabel.mp3
    -rwxr-xr-x 1 sjf staff 6946883 Sep 21 2008 06 Hasta Mi Final.mp3
    -rwxr-xr-x 1 sjf staff 8258438 Sep 21 2008 07 Heroe.mp3
    -rwxr-xr-x 1 sjf staff 7426701 Sep 21 2008 08 En Aranjuez Con Tu Amor.mp3
    -rwxr-xr-x 1 sjf staff 7384893 Sep 21 2008 09 Esisti Dentro Me.mp3
    -rwxr-xr-x 1 sjf staff 7490253 Sep 21 2008 10 Pour Que Tu M'aimes Encore.mp3
    sol:Music sjf$ ls -al /Network/media/Music/iTunes/iTunes\ Media/Music/Il\ Divo/Ancora/
    total 134635
    drwxr-xr-x 2 sjf staff 16384 Dec 28 14:54 .
    drwxr-xr-x 3 sjf staff 16384 Dec 26 12:23 ..
    -rwxr-xr-x 1 sjf _lpoperator 7504453 Sep 21 2008 01 All By Myself (Solo Otra Vez).mp3
    -rwxr-xr-x 1 sjf _lpoperator 8199903 Sep 21 2008 02 Isabel.mp3
    -rwxr-xr-x 1 sjf _lpoperator 7715100 Dec 26 12:21 04 You Raise Me Up (Por Ti Seré).mp3
    -rwxr-xr-x 1 sjf _lpoperator 7970882 Dec 26 12:22 05 Si Tú Me Amas.mp3
    -rwxr-xr-x 1 sjf _lpoperator 6946883 Sep 21 2008 06 Hasta Mi Final.mp3
    -rwxr-xr-x 1 sjf _lpoperator 8258438 Sep 21 2008 07 Heroe.mp3
    -rwxr-xr-x 1 sjf _lpoperator 7426701 Sep 21 2008 08 En Aranjuez Con Tu Amor.mp3
    -rwxr-xr-x 1 sjf _lpoperator 7384893 Sep 21 2008 09 Esisti Dentro Me.mp3
    -rwxr-xr-x 1 sjf _lpoperator 7490253 Sep 21 2008 10 Pour Que Tu M'aimes Encore.mp3
  • StephenB's avatar
    Why not do the rsync NAS to NAS using a backup job on the 2120?
ProSupport for Business
