mr3rown
Jul 23, 2014Aspirant
Unplugged 4th Drive, Now nothing works anymore! #23575559
This is completely random, I simply unplugged the 4th Drive to explaining to a friend how simple it is to change drives when you want upgrade he size, then all of sudden it says drive "Degraded" ... h...
Jul 23, 2014Guru - Experienced User
When you removed the first drive, then in fact the array was degraded (no longer redundant). When you reinsert it, a RAID resync is needed before the array becomes redundant again. That takes time - generally hours.
If you removed a second drive before the resync completed, then you destroyed the array and you have likely lost your data. If you removed drive 4 again, then there is a chance.
In either case, you should contact support (support.netgear.com). You have phone support if you purchased within the last 90 days.
