mr3rown
Jul 23, 2014Aspirant
Unplugged 4th Drive, Now nothing works anymore! #23575559
This is completely random, I simply unplugged the 4th Drive to explaining to a friend how simple it is to change drives when you want upgrade he size, then all of sudden it says drive "Degraded" ... h...
Jul 24, 2014Guru - Experienced User
Personally I'd contact support first. The more you mess with it, the lower the odds of getting your data back.
mr3rown wrote: I only removed the 4th drive, but it no longer can see the 3rd or 4th. Gonna plug it back it in.
