jungle_roger
Feb 12, 2016Aspirant
Update 6.4.2 wake-on-LAN issue
Hi, since updating to 6.4.2, I am unable to switch off Wake-on-Lan. I assume it is that feature as the network stays connected when switched off. I've also noticed that http and https have been enab...
mdgm-ntgr
Feb 12, 2016NETGEAR Employee Retired
Can you clear your web browse cache (e.g. Temporary Internet Files), close your web browser then reopen the web admin page and see if you can change the settings?
Which web browser and version are you using?
Can you try a different web browser?
jungle_roger
hi, I'm using Chrome : Version 48.0.2564.109 m
Have just tried clearing the cache and tried edge.
still cant get it to disable even though the box is unticked.
- StephenBFeb 12, 2016Guru - Experienced User
You need the service for the web ui.
I'm not sure what you want to accomplish, perhaps you can clarify?
- jungle_rogerFeb 12, 2016Aspirant
I have wake-on-lan disabled, since the update its been re-enabled for some reason and i cant turn it off.
Talking about disabling the https service made the thread confusing, so I didn't realize you were talking about WoL.
You are saying that the system responds to WoL even when the check box is cleared? Or that the check box won't clear (or won't stay cleared)?
