jungle_roger
Feb 12, 2016Aspirant
Update 6.4.2 wake-on-LAN issue
Hi, since updating to 6.4.2, I am unable to switch off Wake-on-Lan. I assume it is that feature as the network stays connected when switched off. I've also noticed that http and https have been enab...
jungle_roger
hi, I'm using Chrome : Version 48.0.2564.109 m
Have just tried clearing the cache and tried edge.
still cant get it to disable even though the box is unticked.
Feb 12, 2016Guru - Experienced User
You need the service for the web ui.
I'm not sure what you want to accomplish, perhaps you can clarify?
- jungle_rogerFeb 12, 2016Aspirant
I have wake-on-lan disabled, since the update its been re-enabled for some reason and i cant turn it off.
- StephenBFeb 12, 2016Guru - Experienced User
Talking about disabling the https service made the thread confusing, so I didn't realize you were talking about WoL.
You are saying that the system responds to WoL even when the check box is cleared? Or that the check box won't clear (or won't stay cleared)?
I havn't tested whether the wake-on-lan feature is actually enabled, my issue is that the LAN LEDs stay on when its switched off.
(I mentioned the http stuff as both those and the WOL were disabled before the update)
