buchhla
Sep 22, 2012Aspirant
update firmware via ssh? Case #19355863
Hi, I have a NV+ v2 that I have been unable to get the web interface working on for some time now. I think support is running out of ideas on what to look for short of remote access to the machine, b...
buchhla
Sep 23, 2012Aspirant
Frontview log
I also restarted the service, no errors other then the certifcate error that you see in the log above, but frontview still show device is offline. Some things do work, it does show correct volume space and a few other things, but most of the site is broken.
I did poke around the other logs in /var/logs and didn't see anything there that looks strange.
[Fri Sep 07 12:19:46 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Fri Sep 07 12:20:12 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Fri Sep 07 12:20:12 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Fri Sep 07 12:20:23 2012] [notice] caught SIGTERM, shutting down
[Fri Sep 07 12:20:38 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Fri Sep 07 12:20:54 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Fri Sep 07 12:20:54 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Fri Sep 07 12:53:41 2012] [notice] caught SIGTERM, shutting down
[Sat Sep 08 16:53:26 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 08 16:54:01 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 08 16:54:01 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 08 16:56:57 2012] [error] [client 192.168.1.150] AuthExtern pwauth [/usr/bin/pwauth]: Failed (2) for user admin
[Sat Sep 08 16:56:57 2012] [error] [client 192.168.1.150] user admin: authentication failure for "/admin/": Password Mismatch
[Sat Sep 08 16:57:05 2012] [error] [client 192.168.1.150] AuthExtern pwauth [/usr/bin/pwauth]: Failed (2) for user admin
[Sat Sep 08 16:57:05 2012] [error] [client 192.168.1.150] user admin: authentication failure for "/admin/": Password Mismatch
[Sat Sep 08 16:57:13 2012] [error] [client 192.168.1.150] AuthExtern pwauth [/usr/bin/pwauth]: Failed (2) for user admin
[Sat Sep 08 16:57:13 2012] [error] [client 192.168.1.150] user admin: authentication failure for "/admin/": Password Mismatch
[Sat Sep 08 16:57:21 2012] [error] [client 192.168.1.150] access to /admin/ failed, reason: user 'root' does not meet 'require'ments for user/valid-user to be allowed access
[Sat Sep 08 17:11:17 2012] [notice] caught SIGTERM, shutting down
[Sat Sep 08 20:53:19 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 08 20:53:43 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 08 20:53:43 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 08 21:05:50 2012] [notice] caught SIGTERM, shutting down
[Tue Sep 11 12:14:37 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Tue Sep 11 12:15:16 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Tue Sep 11 12:15:16 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Tue Sep 11 14:12:12 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Tue Sep 11 14:12:58 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Tue Sep 11 14:12:59 2012] [warn] pid file /var/log/frontview/apache-ssl.pid overwritten -- Unclean shutdown of previous Apache run?
[Tue Sep 11 14:12:59 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 22 12:14:36 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 12:15:02 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 12:15:02 2012] [warn] pid file /var/log/frontview/apache-ssl.pid overwritten -- Unclean shutdown of previous Apache run?
[Sat Sep 22 12:15:02 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 22 12:36:19 2012] [notice] caught SIGTERM, shutting down
[Sat Sep 22 12:44:05 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 12:44:28 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 12:44:28 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 22 13:33:01 2012] [notice] Graceful restart requested, doing restart
apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.1.150 for ServerName
[Sat Sep 22 13:33:32 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 13:33:33 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 22 13:33:52 2012] [notice] Graceful restart requested, doing restart
[Sat Sep 22 13:33:52 2012] [error] (9)Bad file descriptor: apr_socket_accept: (client socket)
[Sat Sep 22 13:34:31 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 13:34:31 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 22 14:22:14 2012] [notice] caught SIGTERM, shutting down
[Sat Sep 22 14:23:56 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 14:24:18 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sat Sep 22 14:24:18 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sat Sep 22 14:42:45 2012] [notice] caught SIGTERM, shutting down
[Sun Sep 23 16:19:13 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sun Sep 23 16:19:57 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.200' does NOT match server name!?
[Sun Sep 23 16:19:57 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
