ksor1
Jun 04, 2015Aspirant
Update OS and Raidar ???
I have a ReadyNAS Duo from MAY 2011 - the Raidar About says version 4.1.3 and when I run it the INFO for my ReadyNAS Duo is 4.1.7. Can I update Raidar and the OS ... without having to re-new some h...
Nhellie
Jun 04, 2015Virtuoso
ksor wrote: I have a ReadyNAS Duo from MAY 2011 - the Raidar About says version 4.1.3 and when I run it the INFO for my ReadyNAS Duo is 4.1.7.
Can I update Raidar and the OS ... without having to re-new some hardware ?
Yes you can. updating the OS does not mean you also need to update the hardware, updating the FW is to improve performace of your device and for bug fixes as well. Raidar is used to monitor the NAS on your network.
