ksor1
Jun 04, 2015Aspirant
Update OS and Raidar ???
I have a ReadyNAS Duo from MAY 2011 - the Raidar About says version 4.1.3 and when I run it the INFO for my ReadyNAS Duo is 4.1.7. Can I update Raidar and the OS ... without having to re-new some h...
vandermerwe
Jun 04, 2015Master
If you are in the process of attempting data recovery then why would you want to upgrade the firmware?
That said, it shouldn't affect the data volume, but why risk it?
Have you contacted Netgear about your data recovery?
