ksor1
Jun 04, 2015Aspirant
Update OS and Raidar ???
I have a ReadyNAS Duo from MAY 2011 - the Raidar About says version 4.1.3 and when I run it the INFO for my ReadyNAS Duo is 4.1.7. Can I update Raidar and the OS ... without having to re-new some h...
mdgm-ntgr
Jun 05, 2015NETGEAR Employee Retired
If you press for it there is data recovery available for purchase provided you are the original purchaser of the unit. Note data recovery is purchased with the understanding that attempts to get your data back may be unsuccessful.
It's best practice to backup so if you go and delete something you should still have the data.
