ksor1
Jun 04, 2015Aspirant
Update OS and Raidar ???
I have a ReadyNAS Duo from MAY 2011 - the Raidar About says version 4.1.3 and when I run it the INFO for my ReadyNAS Duo is 4.1.7. Can I update Raidar and the OS ... without having to re-new some h...
ksor1
Jun 05, 2015Aspirant
mdgm wrote: If you press for it there is data recovery available for purchase provided you are the original purchaser of the unit. Note data recovery is purchased with the understanding that attempts to get your data back may be unsuccessful.
It's best practice to backup so if you go and delete something you should still have the data.
I normally HAVE backup of my data but in this case I fooled around and deleted some video files while copying some new files to the drive - so the deleted ones has not yet been backed up.
How would the practice be for a "recovery case" - can it be done remotely ?
