ksor1
Jun 04, 2015Aspirant
Update OS and Raidar ???
I have a ReadyNAS Duo from MAY 2011 - the Raidar About says version 4.1.3 and when I run it the INFO for my ReadyNAS Duo is 4.1.7. Can I update Raidar and the OS ... without having to re-new some h...
ksor1
Jun 05, 2015Aspirant
wli wrote: Duo v2 has recycle bin folder for smb/cifa shares, did you check if Duo v1 has it?
Unfortunately it was not activated :( !
But I thorght - like in Windows - you could recover it from the raw data distruted on the disc.
A program could do that ... just like in Windows,
