Esoteric
Oct 10, 2015Tutor
Updated firmware for my readyNAS RN10400
It's been booting ever since I updated the firmware. Found this answer looking through the forums: https://community.netgear.com/t5/Using-your-ReadyNAS/After-update-firmware-6-4-0-RN10400-does...
Esoteric
Oct 15, 2015Tutor
Contacted support. There is no Mac fix. Needed to setup the bootable USB from a friends PC. Not the most ideal fix...
- JennCOct 16, 2015NETGEAR Employee Retired
Hello Esoteric,
I found your support case and viewed it. It appears support people were able to narrow the problem down to your Mac Yosemite since other computers on the network work with no issue. The NAS works just the same with other LAN devices on the network, it gets IP address and share folders that are designed and configured to share.
I suggest checking the LAN speed of your Mac. You may try sharing a folder on one of your Windows to the network and try accessing it on your Mac and see if the same problem. If the Mac is wirelessly connecting to the network, observing if same problem when wired on it will also help.
