billny9h
Apr 13, 2025Aspirant
updated machine to win 11 and lost shre files on rn204
win 11 update from 10 lost my ability to share files and map drive...rn204 sw6 explorer shows the drive but will not map/// added smb1. did other stuff also ... still no
Apr 13, 2025Guru - Experienced User
Does it work if you use the IP address instead of the hostname? (\\x.x.x.x)
billny9h wrote:
added smb1.
Not necessary, since the RN200 series supports SMB 3.1
- billny9hApr 13, 2025Aspirant
tnx to GURU that fixed it i addressed as the ip address...
tnx
- SandsharkApr 13, 2025Sensei
For reasons I have not yet found, that sometimes happens between Windows and Linux servers. It's the case on one of my three computers. I've seen the same problem reported on other forums, so it's not just ReadyNAS. If you do want to be able to address your NAS by name, add it to your hosts file (just Goggle how to do that).
