Thresherinc
Oct 06, 2016Aspirant
Updates 6.5.2 and 6.6.0 reintroduced RN10400 Chrome Upload Problem
I think the issue fixed in this previous release
ReadyNAS OS 6.1.5 Release Notes: (Dec 2013)
Enhancements & Bug Fixes:
- Fixed drag and drop file compatibility with Chrome
Has been re-introduced over the last 2 releases, first noticed it after 6.5.2 and then with the quick release of 6.6.0 I hoped it had been repaired, but alas and alack it is still there.
I can use Microsoft Edge to upload, but both Chrome and Firefox will not work properly.
I have flushed my web cache and rebooted my NAS but to no avail.
I'm not keen on using Edge, but it'll do as a work around.
- JennCNETGEAR Employee Retired
Hello Thresherinc,
Do you mean to say drag and drop files when browsing the shares in the admin page?
I tried this just now and it does work on my Chrome.
Hello Thresherinc,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to post the fix and mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- ThresherincAspirant
I stopped trying to use the drag and drop method because it was too flaky.
I'm not sure that telling me it works on yours was a solution.
In the end I reworked the way I use the NAS to get a more permanent fix.
