ckelly33
Dec 03, 2013Aspirant
Updating firmware...FOREVER
I decided to upgrade my NAS's firmware and I usually do it manually, so I downloaded it. The version I downloaded was RAIDiator 4.1.13 (Sparc) but my ReadyNAS Duo (v1) didn't like it so I decided to ...
Dec 04, 2013Guru - Experienced User
All you needed to do with a new disk was insert it, and then power up. The NAS will automatically do a factory install on an empty disk.
Either way, there is a delay (about 10 minutes) before the install starts, to give you a chance to choose xraid or flexraid with RAIDar. What is RAIDar telling you now?
