Davidk101
Jun 24, 2021Aspirant
UPDATING FIRMWARE ON READYNAS ULTRA 2 MODEL RNDU2000
This is an old device, fitted with 2x2Tb drives in RAID. I had so much trouble getting it set up using windows 7 initially that I have since left it alone - if it ain't broke, don't fix it. It's an...
- Jun 25, 2021
Stephen,
That change worked a treat. much simpler. Thanks a bunch.
michaelkenward
Jun 25, 2021Guru - Experienced User
The RNDU2000 is a READYNAS thing. You have posted your message in the section of this community given over to
Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but READYNAS is not a router so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
