lem3ssie
Nov 16, 2012Aspirant
Updating Raidiator
Hi, is it possible to update raidiator via ssh ?, without accessing dashboard cause I can't anymore.
Thanks
Thanks
- lem3ssieAspirantThis is what i have :
apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.30.11 for ServerName
Syntax OK
httpd not running, trying to start
(98)Address already in use: make_sock: could not bind to address [::]:443
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:443
no listening sockets available, shutting down
Unable to open logs - mdgm-ntgrNETGEAR Employee RetiredWhat's the output of
# ps ax | grep apache
# ps -ef
Also are you using this?: http://gitorious.org/readynas/apache-configs (if you are then you might need to re-install this)
Did you edit /etc/default/services like I suggested? - lem3ssieAspirant
5828 ? Sl 2:08 java -cp felix.jar -Dcore.conf.file=/etc/frontview/addons/bin/APPGENIE/cp.d/fluid-core.conf -Dfelix.config.properties=file:/etc/frontview/addons/bin/APPGENIE/cp.d/config.properties -Dorg.osgi.framework.storage=/etc/frontview/addons/bin/APPGENIE/cp.d/osgi-config -Dcore.logging.level=4 -Dgosh.args=--noi -Dcore.pgw.ssl=true -Dorg.osgi.framework.bootdelegation=javax.net.ssl -Dcore.model.name=readynas -Dcore.manufacturer.name=Netgear -Dcore.model.number=readynas -Dcp.package.version=5.3.7-0.0.82 org.apache.felix.main.Main
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 Nov16 ? 00:00:35 init [2]
root 2 0 0 Nov16 ? 00:00:00 [kthreadd]
root 3 2 0 Nov16 ? 00:00:00 [ksoftirqd/0]
root 4 2 0 Nov16 ? 00:00:00 [events/0]
root 5 2 0 Nov16 ? 00:00:00 [khelper]
root 8 2 0 Nov16 ? 00:00:00 [async/mgr]
root 123 2 0 Nov16 ? 00:00:00 [kblockd/0]
root 132 2 0 Nov16 ? 00:00:00 [khubd]
root 154 2 0 Nov16 ? 00:00:00 [crypto]
root 155 2 0 Nov16 ? 00:00:00 [crypto_ret]
root 162 2 0 Nov16 ? 00:00:00 [pdflush]
root 163 2 0 Nov16 ? 00:00:00 [pdflush]
root 164 2 0 Nov16 ? 00:00:02 [kswapd0]
root 210 2 0 Nov16 ? 00:00:00 [aio/0]
root 225 2 0 Nov16 ? 00:00:00 [nfsiod]
root 234 2 0 Nov16 ? 00:00:00 [cifsoplockd]
root 240 2 0 Nov16 ? 00:00:00 [crypto/0]
root 522 2 0 Nov16 ? 00:00:00 [scsi_tgtd/0]
root 524 2 0 Nov16 ? 00:00:00 [scsi_eh_0]
root 525 2 0 Nov16 ? 00:00:00 [scsi_eh_1]
root 544 2 0 Nov16 ? 00:00:00 [mtdblockd]
root 545 2 0 Nov16 ? 00:00:00 [nftld]
root 588 1436 0 Nov16 ? 00:00:00 sshd: root@pts/0
root 600 2 0 Nov16 ? 00:00:00 [kstriped]
root 603 2 0 Nov16 ? 00:00:00 [ksnapd]
root 609 588 0 Nov16 pts/0 00:00:00 -bash
root 638 2 0 Nov16 ? 00:00:00 [usbhid_resumer]
root 650 2 0 Nov16 ? 00:00:00 [rpciod/0]
root 689 2 0 Nov16 ? 00:00:01 [md0_raid1]
root 695 2 0 Nov16 ? 00:00:00 [md1_raid1]
root 735 2 0 Nov16 ? 00:00:01 [kjournald]
root 789 1 0 Nov16 ? 00:00:00 udevd --daemon
root 1436 1 0 Nov16 ? 00:00:00 /usr/sbin/sshd
root 1445 2 0 Nov16 ? 00:00:00 [kdmflush]
root 1563 2 0 Nov16 ? 00:00:00 [kjournald2]
root 1564 2 0 Nov16 ? 00:00:00 [ext4-dio-unwrit]
root 1601 1 0 Nov16 ? 00:00:00 /usr/sbin/quota_nld
admin 1651 1 0 Nov16 ? 00:00:02 /usr/sbin/mysqld
root 1730 1 0 Nov16 ? 00:00:02 /bin/bash /opt/photos2/bin/rnp2s
root 1742 1 0 Nov16 ? 00:00:08 /opt/photos2/bin/rnp2d
admin 1753 1 0 Nov16 ? 00:00:01 /opt/photos2/bin/rnp2factory
root 1765 1 0 Nov16 ? 00:00:09 /opt/photos2/bin/rnp2pop
daemon 2218 1 0 Nov16 ? 00:00:00 /sbin/portmap
root 2276 1 0 Nov16 ? 00:00:00 /sbin/syslogd -m 0
daemon 2284 1 0 Nov16 ? 00:00:00 /usr/sbin/atd
root 2297 1 0 Nov16 ? 00:00:00 /sbin/klogd -x -c 3
root 2343 1 0 Nov16 ? 00:00:00 /bin/sh ./cp.d/cpinst/cp_install
root 2347 1 0 Nov16 ? 00:00:00 /opt/readydrop/bin/rdbrokerd
root 2348 2347 0 Nov16 ? 00:00:00 /bin/sh /opt/readydrop/bin/rdhoo
root 2356 1 0 Nov16 ? 00:00:00 /usr/sbin/cupsd
root 2359 1 0 Nov16 ? 00:00:06 readydropd
21 2370 1 0 Nov16 ? 00:00:00 /usr/bin/dbus-daemon --system
root 2372 1 0 Nov16 ? 00:00:00 /usr/sbin/cron
root 2392 1 0 Nov16 ? 00:00:00 noflushd -v -n 10
root 2399 1 0 Nov16 ? 00:00:00 /usr/sbin/smbd -D
root 2405 2399 0 Nov16 ? 00:00:00 /usr/sbin/smbd -D
root 2406 1 0 Nov16 ? 00:00:00 /usr/local/bin/lsyncd -pidfile /
root 2810 2343 0 Nov16 ? 00:00:00 /bin/sh ./cpinst/cp_startup.sh r
root 3224 2348 0 Nov16 ? 00:00:00 /usr/bin/curl -N --tcp-nodelay -
root 3507 1 0 Nov16 ? 00:00:00 ifplugd -i eth0 -q -f -u0 -d0 -w
root 3508 3507 0 Nov16 ? 00:00:00 [ifplugd.action] <defunct>
root 3549 1 0 Nov16 ? 00:00:00 udhcpc -i eth0 -H Readynas -t 3
root 3653 1 0 Nov16 ? 00:00:00 /usr/sbin/raidard
root 3676 1 0 Nov16 ? 00:00:00 /usr/sbin/ntpd -p time-e.netgear
root 3684 1 0 Nov16 ? 00:00:00 /usr/sbin/upnpd eth0
root 3686 1 0 Nov16 ? 00:00:00 /usr/sbin/lld2d eth0
root 3748 1436 0 02:07 ? 00:00:00 sshd: root@notty
root 3750 3748 0 02:07 ? 00:00:00 /usr/lib/openssh/sftp-server
root 4174 1436 0 02:09 ? 00:00:00 sshd: root@pts/1
root 4197 4174 0 02:09 pts/1 00:00:00 -bash
admin 4407 1 0 Nov16 ? 00:00:00 /usr/bin/python -OO /usr/bin/sab
root 4618 1730 0 02:11 ? 00:00:00 sleep 100
root 4646 4197 0 02:11 pts/1 00:00:00 ps -ef
admin 4722 1 0 Nov16 ? 00:06:04 /usr/bin/transmission-daemon --c
admin 4917 1 0 Nov16 ? 00:05:28 /usr/bin/python /usr/share/couch
root 5027 1 0 Nov16 ? 00:00:00 nmbd -D
root 5094 1 0 Nov16 ? 00:01:18 /frontview/bin/monitor_enclosure
root 5108 1 0 Nov16 ? 00:00:00 /usr/sbin/readynasd -t -d /
root 5109 5108 0 Nov16 ? 00:00:00 /usr/sbin/readynasd -t -d /
root 5828 2810 0 Nov16 ? 00:02:09 java -cp felix.jar -Dcore.conf.f
root 5835 5828 0 Nov16 ? 00:00:00 ./execsrv
avahi 5958 1 0 Nov16 ? 00:00:03 avahi-daemon: running [Readynas.
avahi 5959 5958 0 Nov16 ? 00:00:00 avahi-daemon: chroot helper
root 5961 1 0 Nov16 ? 00:00:00 /usr/sbin/readytivod
root 5971 1 0 Nov16 ? 00:00:00 buttond
root 6089 1 0 Nov16 ? 00:00:00 /opt/p2p/bin/leafp2p -n /opt/p2p
root 6104 6089 0 Nov16 ? 00:00:01 /opt/p2p/bin/leafp2p -n /opt/p2p
root 6177 1 0 Nov16 ? 00:00:00 /bin/bash /opt/remote/bin/remote
root 6179 6177 0 Nov16 ? 00:00:00 /opt/remote/bin/remote
root 6201 1 0 Nov16 ttyS0 00:00:00 /sbin/getty -L ttyS0 115200 linu
root 6204 1 0 Nov16 ? 00:00:00 /usr/sbin/minidlna -R
admin 7683 1 0 Nov16 ? 00:01:24 /usr/bin/python /usr/share/sickb
root 32342 2399 0 Nov16 ? 00:00:00 /usr/sbin/smbd -D
root 32345 2399 0 Nov16 ? 00:00:00 /usr/sbin/smbd -D
root 32456 2399 0 Nov16 ? 00:00:17 /usr/sbin/smbd -D
root 32459 2399 0 Nov16 ? 00:00:00 /usr/sbin/smbd -D
root 32576 2399 0 Nov16 ? 00:00:02 /usr/sbin/smbd -D
root 32579 2399 0 Nov16 ? 00:00:00 /usr/sbin/smbd -D
I edited like suggested and tried to restart dashboard but the same message appeared :apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.30.11 for ServerName
Unable to open logs - mdgm-ntgrNETGEAR Employee RetiredCan you try rebooting the NAS?
After the reboot the add-ons you disabled in /etc/default/services won't start.
An alternative would be to run the stop.sh script for each of the add-ons (not Python) in /etc/frontview/addons/bin (if you do this run the one for appgenie as well).
Then attempt to restart the Dashboard again. - lem3ssieAspirantok, how can i run stop.sh from cyberduck or yummy or terminal ?
Thanks.
I found : ./stop.sh
Sometimes it is so easy... - lem3ssieAspirantAfter disabling every plugins except python and tried to restart dashboard: apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.30.11 for ServerName
Unable to open logs - mdgm-ntgrNETGEAR Employee RetiredDid you try a reboot?
What do the "ps" commands give now? - lem3ssieAspirantYes, and this is what the command gives :
root 1 0 1 03:01 ? 00:00:20 init [2]
root 2 0 0 03:01 ? 00:00:00 [kthreadd]
root 3 2 0 03:01 ? 00:00:00 [ksoftirqd/0]
root 4 2 0 03:01 ? 00:00:00 [events/0]
root 5 2 0 03:01 ? 00:00:00 [khelper]
root 8 2 0 03:01 ? 00:00:00 [async/mgr]
root 123 2 0 03:01 ? 00:00:00 [kblockd/0]
root 132 2 0 03:01 ? 00:00:00 [khubd]
root 154 2 0 03:01 ? 00:00:00 [crypto]
root 155 2 0 03:01 ? 00:00:00 [crypto_ret]
root 162 2 0 03:01 ? 00:00:00 [pdflush]
root 163 2 0 03:01 ? 00:00:00 [pdflush]
root 164 2 0 03:01 ? 00:00:00 [kswapd0]
root 210 2 0 03:01 ? 00:00:00 [aio/0]
root 225 2 0 03:01 ? 00:00:00 [nfsiod]
root 234 2 0 03:01 ? 00:00:00 [cifsoplockd]
root 240 2 0 03:01 ? 00:00:00 [crypto/0]
root 522 2 0 03:01 ? 00:00:00 [scsi_tgtd/0]
root 524 2 0 03:01 ? 00:00:00 [scsi_eh_0]
root 525 2 0 03:01 ? 00:00:00 [scsi_eh_1]
root 544 2 0 03:01 ? 00:00:00 [mtdblockd]
root 545 2 0 03:01 ? 00:00:00 [nftld]
root 600 2 0 03:01 ? 00:00:00 [kstriped]
root 603 2 0 03:01 ? 00:00:00 [ksnapd]
root 638 2 0 03:01 ? 00:00:00 [usbhid_resumer]
root 650 2 0 03:01 ? 00:00:00 [rpciod/0]
root 689 2 0 03:01 ? 00:00:00 [md0_raid1]
root 695 2 0 03:01 ? 00:00:00 [md1_raid1]
root 735 2 0 03:01 ? 00:00:00 [kjournald]
root 769 1 0 03:01 ? 00:00:00 udevd --daemon
root 1414 1 0 03:01 ? 00:00:00 /usr/sbin/sshd
root 1423 2 0 03:01 ? 00:00:00 [kdmflush]
root 1541 2 0 03:01 ? 00:00:00 [kjournald2]
root 1542 2 0 03:01 ? 00:00:00 [ext4-dio-unwrit]
root 1569 1 0 03:01 ? 00:00:00 /usr/sbin/quota_nld
daemon 1603 1 0 03:01 ? 00:00:00 /sbin/portmap
root 1662 1 0 03:01 ? 00:00:00 /sbin/syslogd -m 0
root 1716 1 0 03:01 ? 00:00:00 /opt/readydrop/bin/rdbrokerd
root 1717 1716 0 03:01 ? 00:00:00 /bin/sh /opt/readydrop/bin/rdhoo
root 1725 1 0 03:01 ? 00:00:01 readydropd
daemon 1729 1 0 03:01 ? 00:00:00 /usr/sbin/atd
root 1740 1 0 03:01 ? 00:00:00 /bin/sh ./cp.d/cpinst/cp_install
root 1741 1 0 03:01 ? 00:00:00 /sbin/klogd -x -c 3
root 1773 1 0 03:01 ? 00:00:00 /usr/sbin/cupsd
21 1787 1 0 03:01 ? 00:00:00 /usr/bin/dbus-daemon --system
root 1789 1 0 03:01 ? 00:00:00 /usr/sbin/cron
root 1794 1 0 03:01 ? 00:00:00 noflushd -v -n 10
root 1797 1 0 03:01 ? 00:00:00 /usr/local/bin/lsyncd -pidfile /
root 1816 1 0 03:01 ? 00:00:00 /usr/sbin/smbd -D
root 1863 1816 0 03:01 ? 00:00:00 /usr/sbin/smbd -D
root 2215 1740 0 03:01 ? 00:00:00 /bin/sh ./cpinst/cp_startup.sh r
root 2366 1717 0 03:01 ? 00:00:00 /usr/bin/curl -N --tcp-nodelay -
root 2690 2215 0 03:02 ? 00:00:12 java -cp felix.jar -Dcore.conf.f
root 2697 2690 0 03:02 ? 00:00:00 ./execsrv
root 2730 1 0 03:02 ? 00:00:00 ifplugd -i eth0 -q -f -u0 -d0 -w
root 2768 1 0 03:02 ? 00:00:00 udhcpc -i eth0 -H Readynas -t 3
root 2913 1 0 03:02 ? 00:00:00 /usr/sbin/raidard
root 2925 1 0 03:02 ? 00:00:00 /usr/sbin/ntpd -p time-e.netgear
root 2932 1 0 03:02 ? 00:00:00 /usr/sbin/upnpd eth0
root 2935 1 0 03:02 ? 00:00:00 /usr/sbin/lld2d eth0
admin 3041 1 0 03:02 ? 00:00:00 /usr/bin/python -OO /usr/bin/sab
admin 3079 1 0 03:02 ? 00:00:00 /usr/bin/transmission-daemon --c
admin 3099 1 0 03:02 ? 00:00:00 /usr/sbin/mysqld
root 3137 1 0 03:02 ? 00:00:00 /bin/bash /opt/photos2/bin/rnp2s
root 3162 1 0 03:02 ? 00:00:00 /opt/photos2/bin/rnp2d
admin 3186 1 0 03:02 ? 00:00:00 /opt/photos2/bin/rnp2factory
root 3210 1 0 03:02 ? 00:00:00 /opt/photos2/bin/rnp2pop
admin 3284 1 0 03:03 ? 00:00:08 /usr/bin/python /usr/share/couch
root 3374 1 0 03:03 ? 00:00:00 nmbd -D
root 3417 1 0 03:03 ? 00:00:02 /frontview/bin/monitor_enclosure
root 3422 1 0 03:03 ? 00:00:00 /usr/sbin/readynasd -t -d /
root 3423 3422 0 03:03 ? 00:00:00 /usr/sbin/readynasd -t -d /
avahi 3536 1 0 03:03 ? 00:00:00 avahi-daemon: running [Readynas.
avahi 3537 3536 0 03:03 ? 00:00:00 avahi-daemon: chroot helper
root 3548 1 0 03:03 ? 00:00:00 /usr/sbin/readytivod
root 3556 1 0 03:03 ? 00:00:00 buttond
root 3634 1 0 03:03 ? 00:00:00 /opt/p2p/bin/leafp2p -n /opt/p2p
root 3645 3634 0 03:03 ? 00:00:00 /opt/p2p/bin/leafp2p -n /opt/p2p
root 3700 1 0 03:03 ? 00:00:00 /bin/bash /opt/remote/bin/remote
root 3714 3700 0 03:03 ? 00:00:00 /opt/remote/bin/remote
root 3725 1 0 03:03 ttyS0 00:00:00 /sbin/getty -L ttyS0 115200 linu
root 3736 1 0 03:03 ? 00:00:00 /usr/sbin/minidlna -R
root 8609 3137 0 03:23 ? 00:00:00 sleep 100
root 8615 1414 1 03:23 ? 00:00:00 sshd: root@pts/0
root 8636 8615 1 03:23 pts/0 00:00:00 -bash
root 8657 8636 0 03:23 pts/0 00:00:00 ps -ef - kiokomanAspirantput this on the console and report back
netstat -ltnp
