ksor1
Jun 05, 2015Aspirant
Updating the firmware for ReadyNAS DUO v1
When I try to update the firmware from the System/Update, I get this error message back: Error connecting to remote server I'm running Windows 7 Homw Edition and Chrome fully updated. Why can...
ksor1
StephenB wrote: Also the subnet mask needs to be correct.
Nhellie wrote: Your gateway should be your router's IP, for the DNS make sure it is the one supplied by your ISP or use 8.8.8.8 and 8.8.4.4
For almost all home networks it is 255.255.255.0. You can check it using a PC that uses DHCP.
Or better still - change the v1 IP address to automatic, and reserve it in your router to the value you want.
My submasj IS 255.255.255.0 in the ReadyNAS DUO.
How can I "reserve" a specific IP-address to the ReadyNAS DUO in my gateway - is that what you are saying I should do ?
