Ferdi1
Feb 18, 2014Aspirant
Upgrade firmware
Hello, Recently the new firmware for the readynas duo v2 was released. Today I wanted to update using dashboard. Sadly when accessing the dashboard it doesn't get further than the loadingpage. ...
Feb 20, 2014Guru - Experienced User
Robert - are you certain you have a v2? Please check this guide - the labels are confusing: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
If you do have a v2 (and are the original purchaser) then you should probably contact support via email (support.netgear.com). All v2 units are still covered by the Netgear's warranty.
