viperhansa
Sep 28, 2015Virtuoso
Upgrade ReadyNAS Pro Business Edition (My post seems to dissappear)
Hi again guys, I know i posted this a year ago (finally got brave and pushed into try to do an upgrade). Is it the same procedure and are there some limit on how high (or recommended version) i ...
- Oct 07, 2015
I just want to say that mdgm-ntgr and the rest of Netgear staff rock!
I followed the instructions to upgrade my old 4.x.x nas to a new 6.x.x version!
Backup.. Backup.. Backup.... Check my backups... Install PREP4TOR6_0.1-x86.bin from frontview. install R4toR6_6.3.5.bin from frontview. restart.. Put all my data back and hopefully run os6.3.5
And it worked like a charm!
Thank you all for your great work!!
1 side note, is it possible to:
1: have 24 hour clock
2: a app for handling cron works?? :-)
Best regards
Hans
Ramtecrob
Sep 29, 2015Aspirant
also I'm wondering if there is any benefit from increasing from 4GB to 8GB (it was on the stock 1GB until the other day). I will be using as an iscsi tarrgent for VCenter 5.5. Also can I use both the nics to gain faster access?
Sep 29, 2015Guru - Experienced User
You can use both nics (either teamed or separately).
Whether 8 GB memory has any benefit depends on the memory needs of the applications you are running.
