viperhansa
Sep 28, 2015Virtuoso
Upgrade ReadyNAS Pro Business Edition (My post seems to dissappear)
Hi again guys, I know i posted this a year ago (finally got brave and pushed into try to do an upgrade). Is it the same procedure and are there some limit on how high (or recommended version) i ...
- Oct 07, 2015
I just want to say that mdgm-ntgr and the rest of Netgear staff rock!
I followed the instructions to upgrade my old 4.x.x nas to a new 6.x.x version!
Backup.. Backup.. Backup.... Check my backups... Install PREP4TOR6_0.1-x86.bin from frontview. install R4toR6_6.3.5.bin from frontview. restart.. Put all my data back and hopefully run os6.3.5
And it worked like a charm!
Thank you all for your great work!!
1 side note, is it possible to:
1: have 24 hour clock
2: a app for handling cron works?? :-)
Best regards
Hans
Ramtecrob
Sep 29, 2015Aspirant
Thanks, what about the bios upgrade so I can use the e7600 processor, presently on 10/03/2008 FLAME6-MB V1.6, how would I go about it is there a guide?
Ramtecrob
Took a punt on the bios bin chirpa posted. After a reboot bios now 2.0. Then I swapped out the cpu for an e7600 and happy days!
- viperhansaSep 30, 2015Virtuoso
Where did you find the bios.bin file? i have tried to find it.
How did you check your bios version?
I'm running Intel(R) Core(TM)2 Duo CPU E7400 @ 2.80GHz on 4GB ram for ages and i have not had on issue at all.
No fan problems or others...- StephenBSep 30, 2015Guru - Experienced User
If you download the logs, you'll find the bios version in the zip (bios_ver.log). The current version is 07/26/2010 FLAME6-MB V2.0
The bios upgrade download is linked into this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/Ultra-6-Plus-and-Fans/td-p/928243
