mrkzwa
Jan 16, 2014Aspirant
Upgrade single drive in Readynas Duo
Hi, I had one single hard drive with 500gb in Readynas duo, as a media center, so I dont have the second hd. Now I put a second hard drive with 2t and the disk was syncronized. It shows 2 disks with 5...
Jan 17, 2014Guru - Experienced User
The NAS won't expand with only one disk installed.
I think you will need to backup up the data and do a factory reset with the 2 TB drive in place. Then reinstall add-ons, reconfigure, and restore data from backup.
