RaedyNas
Mar 04, 2024Aspirant
Upgrade TLS for OS6 for Syncthing
ReadyNas Pro 6 with OS6 I'm running syncthing that is requesting that my TLS version is outdated and is rejecting connections. Syncthing has the option to allow older version TLS but doesn't look...
- Mar 20, 2024
OS6.10.9 includes OpenSSL 1.0.1t 3 May 2016, which does not include SSL1.3. I was able to successfully install OpenSSL 1.1.0l 10 Sep 2019 on a ReadyNAS virtual machine, but AFAIK that's the last one available for Jessie and it doesn't include support for TLS1.3. You need 1.1.1 for TLS1.3. I've also not done a thorough test, just verified it doesn't break the admin interface.
Mar 20, 2024Guru - Experienced User
AnishaA wrote:
To update the TLS version please find the steps below.
Can you kindly clarify what file you are suggesting RaedyNas should edit?
Also, I am not sure whether you are suggesting that package(s) also need to be updated (or not). If you are suggesting that, can you give more details on which packages?
Sandshark
Mar 20, 2024Sensei
- RaedyNasMar 25, 2024Aspirant
Thanks Sandshark ! That is what I was looking for.
For syncthing it looks like it needed a system restart versus just a software restart to support the older TLS via the backwards compatible software option.
