bsublett
Aug 18, 2022Aspirant
M4250-26G4XF-PoE+ showing TLS 1.0/TLS 1.1 vulnerability
My Tenable scan shows that all of my M4250-26G4XF-PoE+ switches have the SWEET32 vulnerability. When I look at the HTTPS cert it shows that I'm on TLS1.2. How can I set the minimum version to exclude 1.0 and 1.1? I'm on firmware 13.0.2.31.
Thank you.
Brian
Nothing configurable specifically for the AV Web port AFAIK. LaurentMa svp.
Realized there are two device WebUI on these switch model lines? The classic config Web UI, and the other AV Web UI ... the second is not updated.
- bsublettAspirant
Thank you for the assistance! I'm poking around the AV login, but I don't see anything in here for TLS. I must really be missing something--is there just not a way to disable it at this time, not even via the CLI?
